Termination Resistor for NI CAN USB-8473s?
I would like to configure a CAN network consisting of a NI-CAN USB-8473s and a motor controller. So my network consists of just one node which is the motor controller and this has to be connected via the NI CAN USB to the computer. I know I have to add a termination resistor on the motor controller side, since it is end of the line and reflection has to be prevented. However I am wondering if I need to put any external termination resistor on the NI-CAN USB-8473s as well?
(6,072 Views)
Yes, the bus should have a termination resistor on both ends. See chapter 4, Cable Termination of the NI-CAN Hardware and Software Manual for more details.
One solution is to use this cable with a built-in terminating resistor in one end.
(6,063 Views)
