The inductance of motor is below driver inductance range. What are my options?
I am trying to configure an old NEMA 11 stepper motor with a new driver (P70530). When I try to configure the motor in the motor file editor of the driver GUI I keep getting the status of the motor as "overcurrent." and therefore cannot probe or proceed. I am familiar with configuring third party motors (as I have done it before with another NEMA 11 and also a NEMA 42 successfully) so I do not believe my configuration is at all at fault.
I then checked the driver and motor specs and saw that the motor had an inductance per phase (1.2mH) below the drivers inductance range(2-15mH). Seeing that this must be the problem for the failed configuration, I need some advice. This motor is highly customized and I would hate to have to purchase and wait for another and plus I would hate to buy another NI Driver with the correct inductance range because that would but me back ~$2000.  Is there any way to successfully add inductance to the motor via external inductance board or another alternative?
Thank you for your help!
(5,613 Views)
Try adding an inductor in series to each phase to make up the difference.
This may slow down the responce of the motor.
-AK2DM
(5,607 Views)
