Thorlabs APT motor controlling through ActiveX - methods description needed
Hello everyone,
I am currently trying to control my Thorlabs' stepper motor with LabVIEW, through the APT and ActiveX interfaces. I am not looking for a programming advice, but instead in a help to find the API of the APT methods.
As I want to control my motor through LabVIEW, I open an ActiveX container and then I insert my APT interface. now I will be able to program the movements of the motor through the methods of the MG17Motor class. Unfortunately, I cannot find anywhere, neither in Thorlabs website, the complete description of the methods I could use.
I know what the basic method are supposed to do, but other methods are as well available and they could be useful maybe, if only I would have their description...
I know that Thorlabs provide the initial guide to control APT hardware with LabVIEW, but it contains only basic stuff and no description of the methods.
Does anyone has a list with the description of these methods?
Thanks a lot
(6,574 Views)
Hi Matteo,
I'd recommend taking a look at the APTServer Help file which is included with the APT Software installation. Here you can find a full list of ActiveX methods listed by Device Type. I've attached this here.
Hope this helps!
(6,417 Views)
hi!  i do appreciate your reply. Recently i am working on my thesis which is using thorlabs apt for controlling the motor. I've opened your apt server help, but why when i click some topic, there's nothing to be displayed. just white background. Can you help me? thank you.
(6,386 Views)
I see the same thing - not sure how that's happened.
I'd suggest downloading the latest version of APT from the following link. The APT Server Help file is included within this.
https://www.thorlabs.com/software_pages/ViewSoftwarePage.cfm?Code=Motion_Control
(6,381 Views)
I've already downloaded and installed the latest apt software, but where can i find that? the package is only setup program.
(6,367 Views)
After you've ran the Setup.exe installation, you can find the Compiled HTML Help file here:
64-bit Software: C:\Program Files\Thorlabs\APT\APT Server
32-bit Software: C:\Program Files(x86)\Thorlabs\APT\APT Server
(6,364 Views)
