Tuning an optical encoder with a linear actuator
Hello everyone!
I am trying to get an optical encoder (5 lead single ended, incorperated into an Ultramotion D2 series linear actuator) to read the position of the linear actuator's position to 4 decimal figures precision (0.0001), and the DAQ I am using is NI cDAQ 9121 with 2 channels. I decided to use the 65 mV configuration. The encoder has ground, channels A and B, index and 5V leads, of which I have omitted using the index and channel B. Channel A is connected to the AI+. The linear actuator has a scaling of 20,000 steps per revolution and a movement of 4mm per revolution (point to point configuration of the stepper motor drive ST5-S, by Applied Motion).
I am not sure if the above configuration is suitable, but I am limited to the current equipment. I have coded the program using LabVIEW 2014 and, while it seems to give a good estimation of the displacement to the nearest 1 mm,  it is not recording the fractions and counts anything that is 1mm or less as simply 1.
My question is actually threefolds:
1) How can I tune the encoder to read the exact measurement to the nearest 0.0001 accuracy?
2) Am I using an appropriate configuration for the leads?
3) If the problem is not one of the above, could it be something concerning the DAQ software settings and/or the code itself?
Thanks for your advice in advance!
(4,724 Views)
Hey kmhijazi,
Here I share the most general documentation about using encoders with DAQ devices:
Using Quadrature Encoders with E Series DAQ Boards
https://www.ni.com/en/support/documentation/supplemental/21/using-quadrature-encoders-with-e-series-...
Then, here’s a second resource where you can find more details that you can adjust to improve the measurement (i.e the Decoding type, which will however depend on your encoder specifically):
Encoder Measurements: How-To Guide
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
I hope this can help.
>>Daniel C.
(4,656 Views)
