UMI - 7774 connectng to servo drive problems
Hi, I am using a UMI 7774 motion interface to control a Parker Servo drive (AR-08SE).  The Servo Drive requires a differential input for the step and direction signals so I followed this wiring diagram. (http://www.parkermotion.com/scripts/support_faq.asp?rowid=AAAH0UAAKAABvpjAAD&count=1&random_number=1...)  I am using MAX to operate the system but I can not get the servo motor to operate.  It has holding torque but will not turn when I command it to.  I get a "motor off (axis is killed)" and "following error occured" message.  Am I missing something in the software setup?  Or is it a wiring issue?
Thanks, jdb
(3,529 Views)
This could be a wiring issue (e. g. interchanged encoder phases), but there are also other potential reasons. Please refer to this document in the NI knowledge base for further troubleshooting information.
Jochen Klier
(3,520 Views)
