06-17-2009 11:37 AM
I have the following motion control system: PCI-7340 in the host PC, connected to UMI-7764, and the UMI connected to the P70360 drive according to figure 4.a from the following link, in addition to the required inputs (+5V and Gnd):
http://zone.ni.com/devzone/cda/tut/p/id/3442
The motor used is T21NRLC-LDN, with a double shaft.
The motion control system is perfectly functional in open-loop mode.
My questions are:
1) What are the forward limit, home, and reverse limit terminals good for? I mean, from where do the wires go into these terminals?
2) What is connected to the breakpoint and trigger terminals?
3) If i connect a signal to an analog input on the umi-7764, how can I read it (i mean its binary value)?
4) Are there any pins from the J4 connector of the P7000 drive, besides the ones already used (including pins 19 and 25), that could be connected to any of the unused screw terminals of the UMI? (limits and home, especially).
My intent is to make a more advanced stepper motion control system.
Thanks in advance.
06-18-2009 04:19 AM
Hi Sarevok,
here are the answers to your questions:
Kind regards,
Jochen
