This widget could not be displayed.
Unable to configure Kollmorgen Single Axis AKD drive in Kollmorgen WorkBench
Hello , I'm Khairul .
I am trying to  control the motor AKM54H at specified speed using cRIO RT Controller 9074 & Kollmorgen Single Axis AKD drive.
This is our setup for compactRIO RT Controller 9074 , AKD Drive & Motor (AKM54H) :-
I'm using manual "Getting started with AKD EtherCAT Drive and the LabVIEW NI SoftMotion Module"
>> http://www.ni.com/pdf/manuals/375592d.pdf
Successful part:
1. Set up compactRIO system
2. Connect the AKD EtherCat Drive
3. Install software on NI-max and configure NI RT controller
4. Creating project and adding NI SoftMotion Axis.
Unsuccessful part:
i) Configure the drive  in Kollmorgen workbench
issue >> No drive device appear.
From that issue
i) specify IP address AKD drive try to connect but nothing happen.
Inline image 1
Kindly help me to solve and give solution the problem?.
Thank you in advance.
Message 1 of 1
(2,454 Views)
