Use derivative to control signal
I'm trying to control a heating element by the difference between the user-set target temperature and the (absolute) extreme (user-set) temperature.  I've considered testing for cases using first and second derivatives.  From some reading, I've come across the idea of PID, but I can't view any working, accurate samples to even see if this is where I want to go.  I'm in the planning stage, so I've only minimal code.  My first step is "Intake Temperature Signal" (currently simulated by a gentle sin wave, just for a sim).  Second, "Analyze Temp Signal"; third, "Analyze Temp Derivative(s)"; fourth, "Combine Signals" (somehow); and last, "Re-Analyze (or confirm) Temp Signal".
Thanks!
(4,139 Views)
Oh, for the question -- any directions to where I can see good examples of PIDs, or confirmations that this is the direction that will take me where I want to go?
Thanks!
(4,138 Views)
Accepted by topic author Emm
I've since realized I inadvertantly posted this in the wrong area.  I've re-posted in the correct area, but cannot see how to delete this erroneous post.
(4,133 Views)
Hi Emm,
If you could please post a link to the new thread here, then other users who stumble upon this post can be redirected to the new one.
Thanks!
Marti C
NI Medical
(4,099 Views)
(4,090 Views)
