Using Digitizer with motion card
Sir,
In my application of Non-Destructive Testing of tubes using Ultrasound, I am using a motion card for controlling the motion of the Ultrasound probe (that runs with stepper motor)using the motion card. This probe moves all over the specimen under test. I am using Scope card to get the data from the probe and display and storing the waveform. Now I am moving the Probe step-by-step manner by specifying the step-increment and acquiring the data. Is it possible to acquire the data if i move the probe in the continuous manner by specifying the speed and end position alone? What are all the things i should take in to consideration to get and store the data efficiently?
Kindly help me regarding this.
Ramkumar. D
Soliton Technologies.
(3,424 Views)
Hello Ramkumar,
Thank you for contacting National Instruments. You should be able to use breakpoints to synchronize motion with your digitizer. Breakpoints are used to generate a trigger when a predefined position is reached. Refer to the links below for a tutorial on using breakpoints:
Breakpoints:
http://zone.ni.com/devzone/conceptd.nsf/webmain/6bdfab9d635697a886256802007b99bd?OpenDocument
Using Breakpoints in the Motion Control Module:
http://zone.ni.com/devzone/conceptd.nsf/webmain/3b002f3944487b9b86256aa7006b4e65?OpenDocument
Motion Synchronization with DAQ via (Breakpoint-external Scan Clock), example
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DF6956A4E034080020E74861&p_node=DZ52480&p_source=External
The above link shows you how to synchronize motion with an E-series DAQ card. You should be able to follow the same procedure to synchronize motion with the digitizer. Hope this helps you out. Have a great day!
Nipun M.
(3,406 Views)
Dear Nipun,
Thanks for your valuable suggestions. I will try this out in my application and get back to you if I face any difficulty.
Ramkumar. D
(3,401 Views)
Dear Ramkumar,
You're very welcome. Let me know how things work out for you.
Nipun M.
(3,395 Views)
