Using USB-6008 for closed loop motor control
Hey Jochen,
Thanks for the reply.  I actually did find a Motion Control Selection Guide offered by NI.  So anyone else who is in the same boat perhaps will find this interesting.
http://zone.ni.com/devzone/cda/tut/p/id/3655
Yet,with regard to your third bullet, how does one calculate/measure/find the load inertia?
Steve
Message 11 of 12
(1,478 Views)
Steve,
the selection guide is ok within it's scope, but it's a little bit outdated and it doesn't touch some low-cost solutions, that might be an option depending on your application's requirements. That's why I haven't guided you to this web site.
Calculating a load's inertia is very important for motor sizing. The effective inertia depends on parameters like mass, geometry, gear box ratio and so on. While you can calculate inertia mathematically, you also can use tools for motor sizing, that are provided by many motor vendors. NI is cooperating with Kollmorgen, so you can download their Motioneering tool from our website.
Jochen
Message 12 of 12
(1,476 Views)
