Using a CW230 Bi-polar driver with the UMI-7764 and 7330 PCI. But clock level is loaded below 2v and motor will not run?
I have my stepper driver connected to the +step and aogrnd terminals on the UMI-7764. With the driver connected to these terminals the output across the two is 2vp. When I disconnect the driver, the level returns to a 5vp signal. My drivers inputs are optically isolated so I suspect the impedance my be higher than TTL can drive. Is there any way to manually set the output parameters of the 7330 Motion controller?
Thx...Vic
(3,824 Views)
Hi Vic,
Take a look at this KnowledgeBase:  How Do I get the 73xx Controller and UMI-7764 to Drive a Third Party Stepper Motor?
I think it may have the solution to your problem.  Also, here is another KnowledgeBase that is relavent:
Why Do I have to Supply Power to my UMI-7764?
I don't believe there is a way to manually set the output parameters of the 7330, but I don't think this is the source of the problem.  If the KnowledgeBase articles are not the solution, post back and we'll keep troubleshooting!
Kristen H.
(3,814 Views)
