VCO
I am using a motion control PCI 7344.In my project I want to built a Voltage Controlled Oscillator using labview.But here in my case I will not be using DAQ. So is it possible to built a VCo using pure LabVIEW programming.In VCO my inputs will be duty cycle (T=Ton + Toff) plus frequency in Mhz.The frequency will be in Mhz because I want the output to range between 2micro secs to 100 microsecs.The output will be a digital waveform.
Can this be done.If yes, how?
Regards
Manish karnik
Cruiser Control
India.
Smiley Sad
(3,125 Views)
Manish,
I'm a bit confused by this question so please help me to clarify some things:
  1. What has the 7344 to do with your question?
  2. If you want to build a VCO how do you acquire the control voltage and which device do you want to use for the output? Are you looking for hardware for this task?
Jochen Klier
National Instruments Germany
(3,117 Views)
