Viso missing on UMI 7772
Hi
I intend to wire my UMI 7772 to supply power to the forward, reverse and home sensors.
However, I have been measuring the voltage and there is nothing present.  Both green lights come on for Viso and V on the UMI.
I read the following discussion:
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Do-I-need-to-enable-something-in-MAX-to-turn...
It says there is a fuse blown and it should be returned to NI.  This doesn't make any sense as I can control the Digital outputs on the Digital I/O Dsub, so surely it can't be a blown fuse or it wouldn't be possible to set these?
Does anyone know if there is a way to control the VIso output, either via s/w or and simple h/w fix?
Sean
Message 1 of 9
(7,560 Views)
Hi SeanJ,
I've attached a trouble shooting Knowledge Base that you may find helpful. It will give you some steps that may help debug the system.
http://digital.ni.com/public.nsf/allkb/92DC8DFC11B7DBCB862577BB006A9CF0
Unfortunately I cannot find a SW or HW fix for the issue as you suggested that there might be. Probably the best option is to open a service request by following the provided link below. Then you can contact your local NI branch for repair options and a detailed debug process can begin.
http://www.ni.com/support/
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
Message 2 of 9
(7,435 Views)
Hi ... did you get any resoultion to this issue - I am experiencing the same problem on my D-Sub.
Message 3 of 9
(7,225 Views)
Hi abhalla_1,
Have you followed the steps in "How Can I Test My UMI 7772/7774 for Damage?"
If so what was your outcome?
Kevin R
Message 4 of 9
(7,218 Views)
We seem to be having the same problem with our UMI-7774.  When we followed the instructions from that article to test the Viso, none of the LEDs light up (inhibit all, fwd, home and rev).  Any ideas, other than sending it back to NI, that may provide a fix or work around?
- Thanks
Message 5 of 9
(7,071 Views)
SeanJ Did you find a Solution for this issue.... what was it????
Message 6 of 9
(6,810 Views)
Or anypne with the same issue??
Message 7 of 9
(6,805 Views)
Hi checho,
It's been a while, I didn't have to return the UMI.  I think it was justy not isolated in the way I expected.
I'm afraid I'm working in a different company now and can't recall the full details.
Good luck!
Message 8 of 9
(6,794 Views)
Our issue ended up being the extra wires (that we didn't connect to anything) from the D-Subs were getting grounded out against the shield or each other - causing a short.
Amit
Message 9 of 9
(6,792 Views)
