Want to control 7344 Motion step rate creep test program
The HTML conversion doesn't work well, so please see attatchement for description of problem.  I've attempted to truncate the description so many times now that it almost no longer makes sense.  Contact me with questions.
In summary, I need help
(2,923 Views)
The first thing that comes to my mind when I read your problem description is: Why are you using a stepper motor for this task? The application you describe is predestined to be solved with a servo motor. In fact the best solution would be to use a servo motor with analog feedback.
What you try to do is in fact a force control application running under Windows. As Windows is not a real-time operating system you will never reach a stable cycle time of 0.01 s. There will always be a considerable amount of jitter destabilizing your control algorithm. Even if you use a PID algorithm in your loop I'm pretty sure that the result won't be very satisfying. Additionally stepper motors can't handle varying loads very well and they tend to oscillate in this scenario making it even harder to find stable control parameters.
If you use a servo motor with analog feedback you can use your analog force signal directly as a feedback signal for the PID loop that runs on the DSP of the 7344 under real-time conditions. You can either use the normal move constraints as velocity and acceleration to control the way the force increases or you could even use contouring mode for a more sophisticated control.
This method will speed up your application very much, you will get smooth moves and stable system behavior.
Jochen Klier
National Instruments Germany
(2,915 Views)
