What can make flex_enable_axis cause a wrong mode error, i.e. NIMC_wrongModeError?
I am currently getting a wrong mode error caused by enabling my axis. I realize the error is caused when flex_enabled is used at an illegal time, but what can make it run at an illegal time?
I am currently trying to set my axis with certain configurations. I use the flex functions in this order:
flex_initialize_controller(boardID, 0);
flex_clear_pu_status(boardID);
flex_enable_axis("disable all axis");
flex_enable_adcs("enabled ADC channel 1");
flex_config_axis("configure axis 1: primary feedback:ADC channel 1 and primary output: DAC channel 1);
flex_enable_axis("enable axis 1"); //This is where error occurs.
How is enabling axis 1 here an illegal time?
If anyone can explain to me, it would be greatly appreciated. Thanks!!
(3,680 Views)
Thank you for using our discussion forums. Would it be possible for you to post your application that is giving this error. I just tried the same procedure in LabVIEW and the sequence ran in this order without a problem. Also, let us know what programming environment you are using.
Nipun M
(3,672 Views)
Hi Nipun,
I am using Labview 7.0 in junction with measurement studio for VC++. I resetted the board and now it works ok. But this kind of situation kind of scares me since I never realized why the error message popped up. Anyways, thanks for your efforts!
(3,667 Views)
It might be also a good idea to upgrade to NI-Motion 7.0 if you haven't done, yet. This is especially important if you are using an NI-Motion version older than 6.1.x
Jochen Klier
National Instruments Germany
(3,663 Views)
