What driver to be used for PXI-7324 in WinXP system
Hello all!
I have a PXI system with a PXI-7324 motion controller, the operating system is WinXP with Labview 7.0.
Initially I had Valuemotion installed and when I was looking in MAX the hardware appeared in the devices list, when I was trying out the hardware with the interactive fucntins I got an error message about pcmotion32.dll
I decided to upgrade my driver to MI-Motion 6.1.2 and the installation went fine but when I'm looking inte the MAX device list I do not see my hardware. After some reading I realized that the controller is not supported under NI-Motion 6.1.2.
My question is: is there a driver that I can use for the PXI-7324 under WinXP or do I have to replace the hardware?
WinXP is a requirement from out IT department.
Jaan
(3,085 Views)
Hello Jaan,
To be able to use the PXI-7324 you should use the Valuemotion 5.0.2, but this driver isnt supported in WinXP so it would most likely not work in your system.
The Motion control R&D team is no longer releasing ValueMotion software, therefore the motion team will not make any revisions to the current software.
However the new PXI-7334/7344 (https://www.ni.com/en-us/support/model.pxi-7344.html) Controller meets the need for a low-cost motion controller, thereby replacing the entire line of ValueMotion products. So in your case the best option would be to change to the 7334/7344 controllers and use the NI-motion drivers.
Regards
Message Edited by AshwaniS on 03-01-2006 08:28 AM
Ashwani S.
National Instruments Sweden
(3,074 Views)
