10-18-2006 10:43 PM
10-19-2006
02:31 AM
- last edited on
04-24-2024
04:48 PM
by
Content Cleaner
The easiest way to control a standard DC motor is using a motion control board like the PCI-7342 that runs the control algorithm onboard. As this board outpus a +/-10 V control signal a power drive (e. g. MID-7602) is needed to generate the PWM current signal for the motor. If the MID-7602 doesn't meet your needs the PCI-73xx boards can also interface to most 3rd party drives through a UMI.
There are even more options, e. g. building your own motion controller with real-time hardware or FPGA based devices but for standard motion control tasks this is typically not needed.
Please let me know if you need more specific information. In this case please provide some insight into your application.
Jochen Klier
National Instruments Germany
10-19-2006 07:23 AM
Jochen,
Thanks, I was exploring those devices last night. Would it also be reasonable to generate a pulse train and send it through the digital outputs of a USB-6210 (since I already have that device)? From there I could send those pulses through a drive or amplifier circuit, then send that to a mechanical relay which could give me the current I need to supply the motor? I don't see why this would not work but please let me know. And thanks for the suggestions.
Joe
10-19-2006 07:37 AM
10-19-2006 07:47 AM
Jochen,
Ok, so I guess I will have to go with the controller. That way I can have more control over speed and close the loop. Does the motion controller provide the quadrature encoder and such devices to keep track of position and velocity? The reason that I'm using a DC motor is because we're using a worm gear reducer for a heavy load lifting application. It is hard to find a cheap stepper for high torque applications. I had anticipated spending a lot of money for computer hardware but not for mechanical parts such as a motor and gear reducer. Now, if I get the motion controller and power drive, will I need anything else? Do the leads from the motor go straight into the power drive? Can I switch polarity easily so that the motor can go forward and reverse? Thanks.
Joe
10-19-2006
08:04 AM
- last edited on
04-24-2024
04:48 PM
by
Content Cleaner
Joe,
I hope that helps,
Jochen
Message Edited by Jochen on 10-19-2006 03:05 PM
10-19-2006 08:56 AM
Excellent, you're information was most helpful. If I have anymore questions then I'll just post again. Thanks a million.
Joe
10-19-2006 09:17 AM
You've kinda got 2 threads going on this same subject.
How tightly do you need to control the speed? Do you care about position, other than at the end of travel limits?
10-19-2006 11:47 AM
03-12-2009 09:37 AM
