08-18-2009 11:17 AM
Hi
I'm trying to debug an automated system thats running on a MID7604 controller. I have some (limited) electronics backgroud and am a bit confused on the 'Breakpoint' feature of the controller. Basically I have a keypad with several push buttons on. The seperate LEDs that illuminate the buttons are connected to +5v and then to one of the 4 breakpoint terminals on the MID7604. The LED no longer lights and am guessing the software is not 'turning on' the breakpoint. Is the breakpoint like an interrupt?
08-20-2009 07:05 AM
Hello noodlesuk,
Here is the definition of a breakpoint in motion applications:
"A motion controller can be configured to generate a trigger signal or toggle the state of an I/O port when the motor reaches a specified position.
This specified position is called a breakpoint and is similar to a switch that is triggered after the motor passes a certain position."
These following articles will help you as well:
http://zone.ni.com/devzone/cda/tut/p/id/3916
http://zone.ni.com/devzone/cda/tut/p/id/4512
http://digital.ni.com/public.nsf/allkb/BC12076576636530C1256F01007862F9
Kind Regards,
Michael S.
Applications Engineer
NI UK & Ireland
