What is the best way to limit current on a conveyor (2hp 3ph) motor to protect belting from jams?
I have a plastic modular link conveyor that every time it jams it destroys the belt because the geared 2 hp 3ph motor is too powerful.  I am driving the motor with a Siemens Micromaster 420 VFD.  When I adjust the current max, the frequency changes automatically and proportionally which is not good since I do want to maintain belt speed.  I am told by the belt manufacture that this is just the way it is and that there is no way to overcome this.  I don’t buy this doesn’t seem logical and I have other equipment that if they jam the belt stalls but does not break.  Any thoughts?
(4,450 Views)
There are mechanical clutches available to limit the torque of the drive. However, I have no experience with these and cannot tell you about performance.
(4,437 Views)
Normally, adjusting the max current in the drive is what you want to do.  I don't know why that drive scales frequency with current.  Normally voltage and frequency remain proportional.  Be sure you are adjusting a max current parameter(or torque if available), and not a rated current that is used to alllow the drive to run properly.  As mentioned, a better alternative may be a torque-limiting clutch or coupling.  Zero-Max and R&W are 2 names that come to mind.
(4,433 Views)
