What is the required hardware to control AMC servo amplifier model 30A20AC?
Hi everybody,
What is the required hardware to control "Advanced Machine Controls" servo amplifier Series 30A-AC, model 30A20AC?
The interface hardware should connect to a laptop, and run in real-time.
Tnank you
(3,450 Views)
Hi Nkhbeik,
I went to ni.com/motion >> choose NI Motion Hardware.  I then filtered out the hardware that did not support Real-Time by clicking on Real-Time on the left hand side of the page.  There are a number of results returned.  Depending on how many axis you need, you can filter the results further.  Any of the results can be used with the appropriate connector, either a cRIO chassis (for the 9505), a PXI Chassis (for PXI formfactor), or a PCI Extension device for a PCI card.  I hope this helps!
Kristen H.
Message Edited by Kristen H. on 06-08-2009 01:22 PM
(3,441 Views)
