10-10-2006 09:34 AM
10-10-2006 11:08 AM
10-11-2006 02:27 AM
10-11-2006 04:53 AM
10-11-2006 07:18 AM
Thanks for your replies to this topic. I just discovered the worm gear option yesterday while talking to a professor. I think that is the route we are going to take because the DC motor won't be as expensive as a high-torque stepper or servo. Also, I have three engineers that will be calculating the motor size based on gear reduction, spool size, cable length, and the load that we have to lift (which is about 120 lbs.). If any of you would like to suggest a motor size, that would be great too. I'm thinking something around 1HP should probably do it. My goal is to stay cost-effective while making an easy apparatus. I know that the worm gears may also be inefficient at times but it seems like the best solution for this application. Not to mention it's not to hard for our mechanical engineers here to make the spool and bearings. And I believe you can buy a DC motor that interfaces directly with a worm gear. However, a follow up question is what computer hardware do I need to control the voltage of the motor so I have speed control? Is this done through an RS232 board? My output from the LabVIEW program will be voltages, from which device is that binary signal converted into physical voltage? Thanks for your help so far.
10-11-2006 01:30 PM
10-16-2006 08:48 AM
10-16-2006 09:50 AM
10-16-2006 01:15 PM
10-16-2006 01:22 PM
