When are blends superimposed?
I am having a little bit of trouble with a series of blended one-axis moves. I am moving a slide table back and forth. Each "move profile" consists of a series of blended moves to carry the slide across the table and then back. The velocities change at specific positions across the table, creating a 'trapeziod' effect across the table and back. If I create the exact same velocity/accelleration/position profile across the table and back (except reversed), I would expect the actual velocity profile, as graphed by LabVIEW in realtime, to be identical. (See example below). However, it seems that the blended moves are delayed somewhat, so that the velocity profile across the table appears offset from the profile of the return trip. I have to use t
rial and error to get an exact overlap of the proviles, by changing the across trip positions to be a little less than the return trip positions.
My question is, since the blended move funtion surely operates as it should, then exactly how is the blend accell/decel superimposed on the current velocity move? I would like to know these equations so that I can properly calculate my profiles instead of relying on trial and error.
Michael Hampson
XL Automation, Inc.
EXAMPLE:
If the slide table is 10" travel, then a blended profile may consist of the following:
Start position is 0"
MOVE Position Velocity Accel/Decel
1 2" 100RPM xxx rpm/s
2 5" 200RPM xxx rpm/s
1 10" 100RPM xxx rpm/s
1 5" 100RPM xxx rpm/s
1 2" 200RPM xxx rpm/s
1 0" 100RPM xxx rpm/s
This profile should create an offset trapezoid both on the across trip and the return trip. This it does, but the trapezoid created on the return trip is offset from that created on
the across trip. I would like them to everlap exactly.
Michael Hampson
President
XL Automation, Inc.
(3,084 Views)
Michael,
When you load a Blend Factor of '-1', as soon as the first velocity profile finishes its constant velocity section, that is, it starts to deccelarete, the next profile will start to accelerate, and the formula is a simple addition, Vel1+Vel2 = VelProfile. You can see a descriptive graph if in LabVIEW you check the help file for Load Blend Factor VI. So imagine two exact profiles one next to the other same accel and deccel factors and you Blend them, then it will maintain a constant velocity without feeling the deccel/accel portion, makes sense?
Make sure you are waiting for the Blend Complete Status before loading new parameters. And you may want to try a Blend Factor of 0 for changing the direction, just a guess.
Good luck!
Nestor.
Nestor
(3,084 Views)
