11-17-2006 12:35 PM
11-20-2006 04:25 AM
11-21-2006
02:44 AM
- last edited on
02-10-2025
04:54 PM
by
Content Cleaner
Harry,
here are some suggestions for a possible system setup:
Motion Control:
The most cost efficient solution from NI is the PCI-7332 which provides two stepper outputs. It is much cheaper than the PCI-7344 and it should do the job for you.
Measurements:
I would suggest using an M-Series device like the PCI-6220 to acquire the analog signals. The analog inputs of the M-Series provide several features (e. g. hardware timed acquisition, higher accuracy, calibration,...) that make it a much better choice for measurements than the analog inputs of a motion control board.
Please provide some more information about the voltage levels and frequencies of your signals. How fast do you need to reverse the direction when the limit is exceeded?
Jochen Klier
National Instruments Germany
