Make sure that the stepper motors are rated for a higher torque constant than the inetrtia of your load requires, one thing to take into account when uing microstepping is that the more microstepping you apply, the more torque you will lose on the stepper motor. So if your system load and the load your motor can handle are very closely matched, then there is you answer and you will have to either reduce microstepping ratio or get a motor with higher torque rates.
