Why do I get "transmit buffer full" error message?
I periodically receive the above error when trying to execute a series of Blend motions. Why does this occur?
(4,965 Views)
Because the motion board runs it's own onboard processes, comunication between the PC and the board is message bassed. The board has a message queue which it fills up with commands sent by the PC. If commands are issued in too rapid of a sucession it is possible to fill this queue and to return error of the type you are encountering. If you are sending down a number of blended move commands in a loop please make sure to have at least 5ms between each command.
Hope this helps,
Amaury
(4,965 Views)
