03-15-2006 12:59 AM
But in MAX, motor doesn't work with servo type.And there is no signal between AnalogOutput and AnalogOutputGround.
Can I connect UMI to the motor correctly?
Now, I connect encorder signals with changing differential line driver (motor driver) to TTL (UMI) using quadruple differential line receiver.
Is it right?
If it is right, why does the motor work?
Secondarily, when I use stepper type in MAX, the motor work with open-loop. But when I use stepper type in MAX, the motor doesn't work with cloosed-loop.Why?
Polarities of encorders(A, B, Index) make matches my servo motors by setting in MAX.
Why?
megumi
03-15-2006 05:53 AM
03-15-2006 05:27 PM
