Will running a 12 DC motor with 15 volts dc harm it
I Would like to know the adverse effects of running a 12 volt DC motor, with 15 volts dc.
(5,588 Views)
(5,584 Views)
What manufacturer and model? Application and always on and under load?
Depending on what you are doing, yes, it could possibly harm it or dramatically shorten it's life.
(5,584 Views)
It a igarinfo@igusa.com igarashi no 33Gn2732,12 v dc gear motor,  it will be used in a stop and go - aplication
model numbers
  No Load Max Efficiency Stall
Voltage Speed Current Speed Torque Current Output Eff. Torque Current
V RPM A RPM mN-m g-cm oz-in A W % mN-m g-cm oz-in A
37GN2742-133-GF-3 12 85 0.079 67.5 165 1683 23.4 0.29 1.17 34.2 800 8170 114 1.08
(5,580 Views)
drsantos:
The model number in your post does not match the data in the table. I briefly went to igusa's site to see if they had more info regarding voltage range, but did not see anything relevant. It may be best if you contacted igusa directly.
(5,575 Views)
