Yaskawa MECHATROLINK Driver
I have version 9 (2009) of LabVIEW. We I load the Yaskawa MECHATROLINK Driver for LabVIEW Version 1.2.9, it says that it can not find LabVIEW Runtime 8.2.
Is there a new LabVIEW driver for Yaskawa MECHATROLINK that is compatible with LabVIEW 2009?
How do I get the LabVIEW driver for Yaskawa MECHATROLINK to work wit LabVIEW 2009?
THANKS.
(6,954 Views)
Hi dbaechtel
I know this is a Mechatrolunk-II Driver for LabVIEW 8.6. You can find this driver at the page listed below:
http://www.yaskawa.com/site/Products.nsf/products/Multi-Axis%20Motion%20Controllers~mechatrolinkIIdriverLV.html
If the driver does not work you can try performing a mass compile on the componenets and bring this up to LV 2009.
Thank You
Eric Reid
Motion R&D
(6,944 Views)
@Eric_R wrote:
Hi dbaechtel
I do not have source for the driver and it won't install under LabIEW 2009, so I don't know how to "try performing a mass compile on the componenets and bring this up to LV 2009".
Can you suggest a way that I can do this?
(6,942 Views)
The page you referenced at yaskawa.com says "
Sorry, the page you requested was not found."
Can you provide another URL?
(6,941 Views)
Sorry the link did not copy all the way, the driver link is here, and the support link for the driver is here. Since it sounds like the driver is not broken down into individual components a mass compile will not work. My recommendation if the 8.6 driver does not work is to contact Yaskawa and see if they have any plans for a 9.0 or if they can provide you the source code for it so you can perform the mass compile. Please let us know on these forums your findings and if you do get a driver for 9.0 we would all appreciate it if you could attach it to the post.
Thank You
Eric Reid
Motion R&D
(6,926 Views)
