Yaskawa servodrive controlled with s7-1200 via PTO
My question would seem to be stupid for many of you but i still can't solve it myself. I'm trying to control a servodrive SGDM via PTO.
Wiring:
i connected the pin 7 to the pulse output on the siemens board and the the pin 11 to the sign output, while the pin 8 and 12 were connected to the ground.
the problem is the motor turn only in one direction. it seems that the drive doesn't receive the information about the reverse direction.
i attached the wiring diagram of position control mode below.
thanks in advance.
(2,779 Views)
Hey Josef, what hardware from NI are you using?
(2,732 Views)
