aquire data from DAQ while APT is moving
I have a LabView program that collects voltage in a while loop parallel to the rest of the program which moves a Thorlabs rotator and counts with an SR400 photon counter, rotates again, counts etc.
Since I have put a hold function on the rotator for it to finish moving before the SR400 starts, also the voltage collection halts until move is complete. I thought that LabView did things in parallel so that if I put a while loop outside the sequence of the other stuff, that would run continuously no matter what happens in the other part.
Is there a way to make it do what I want?
I also would like to have a common stop button for both parts, but then the voltage measurement won't start until the counter starts.
The counter is started inside a while loop where a button is placed and I thought I could wire that button to the parallel loop but then the latter waits for the status of the button before it begins aquiring data...
(5,452 Views)
Hi otg,
Provided that you have multiple CPU-cores available on your system, LabVIEW will execute all parallel code in parallel. For example, inside a while loop, if two wires of code (with no interdependence) are drawn in parallel, LabVIEW will execute them in parallel. Another example is if you have two while-loops next to each other. As soon as both have started, they will execute in parallel. However, note that if you would utilize a resource that cannot be shared, parallel processing will be halted, or yield an error.
For more information, please take a look at the following two resources:
http://www.ni.com/white-paper/14565/en/
ftp://ftp.ni.com/evaluation/labview/ekit/multicore_programming_resource_guide.pdf
Regarding your question with a common stop button, you could e.g. use local variables, see link below.
http://digital.ni.com/public.nsf/allkb/267704CDE91156D186256F6D00711AAE?OpenDocument
(5,429 Views)
Thank you (Tack ska du ha? (gissar att du är svensk bara) 🙂 )
I'll look into that and see if that solves my problem. Guess the motor control invoke boolean input "wait until move is complete = True" might still mess things up but perhaps I find something in your links that will let my voltage data input run continuously in parallel anyway
(5,426 Views)
