01-05-2011 06:07 AM
Hi
I have a motion system featuring 7332/ UMI 7772/ nema 34 encoder/ N31HRLG & P70360.
I have two major issues.
1. Velocity is wrong.
If I try to set the velocity to 100 step/sec with 200steps/revolution it run at 93 step/s
2. The distance does not correspond to the velocity.
In the attached velocity graph, measured in MAX
distance = 8.1 * 93 = 753 steps
In the attached distance graph total distance = 1000 in 8.1s!!
In order to break this down to it's simplest component. I have remove everything except the 7332.
I would have assumed the 7332 could theoretically run ok but the results show otherwise.
Does anyone have any ideas where I have gone wrong?
Sean
01-05-2011 07:52 AM
I just decided to run the 7332 as follows:
velocity = 1,000 step/s
distance = 20,000 steps
The graph is attached. It is interesting to note that the time period on the graph is approximately 16.1s
I timed it on a stopwatch and got 20.6s, (when taking acceleration, deceleration, human error in account this result is pretty much bang on.)
Perhaps MAX is not working correctly? Is this a bug? Does it happen with the VI's too?
01-05-2011 08:35 AM
I tried Using motion assistant.
I've attached a graph of MAX versus Motion Assistant.
The time periods are different.
Motion assistant matches my stopwatch.
The answer to my question appears to be:
MAX doesn’t work – use Motion Assistant.
I've wasted days trying to get this to work! Can this really be the answer?
01-06-2011 10:45 AM
Hi Sean,
Perhaps it's your settings in MAX that is causing this discrepancy. Please follow this guide to choose your settings: http://zone.ni.com/devzone/cda/tut/p/id/3367#toc1
I thought you might find this useful as well: http://digital.ni.com/public.nsf/allkb/899AE29CB4E3578B8625709D0070A725?OpenDocument
Let me know how you get on.
