bioloid cm-530 control
 I want to know that if bioloid cm-530 could be controlled by Labview.I've saw the VIs for cm-5 but I'm not sure weather they work.
(4,583 Views)
It looks like they offer libraries for labview usage.
You can check the description in the following page.
http://robosavvy.com/store/robotis-cm-530-controller-bioloid-ax-mx-servos.html
http://support.robotis.com/en/software/dynamixel_sdk/usb2dynamixel/window_communication_1/labview.ht...
But if you encounter any problems when using their APIs, you probably have to contact them for further support.
(4,561 Views)
