c-843
Is there a newer version of LabView driver for PI Motor Controller C-842 in the Library?
Julius
(4,531 Views)
Hi Julius,
this driver is developed and maintained by PI, so please check with PI for newer driver versions.
Kind regards,
Jochen
(4,517 Views)
Hi Julius,
Thank you for contacting National Instruments. I had a quick look for drivers for this piece of equipment and I noticed that they had an extremely old VIs. I found the drivers here.
Are you looking for a more updated version of the VIs? Or is there a bug in the existing VIs?
Many thanks,
Andrew McLennan
(4,497 Views)
Hi Julius,
Following onto my original post, I managed to find some more up-to-date VIs for the c-843, which is what this post was originally about (according to the subject line). Please let me know if you need any more information.
Many thanks,
Andrew McLennan
(4,446 Views)
