cRIO Replacement HW for NI 9505
I am looking for a National Instruments or NI reccomended direct replacement for the NI 9505 Brusched DC motor controller'
(2,279 Views)
Unfortunately, it looks like NI has discontinued its NI-Motion control portfolio of software and hardware.
You can purchase the module from resellers like apexwaves https://www.apexwaves.com/modular-systems/national-instruments/c-series/NI-9505
In general, it would be best to redesign to use in-production hardware.
Santhosh
Soliton Technologies
(2,256 Views)
There is no longer NI motion. But you may consider another motion solution that designed for LabVIEW. It is a pulse command generation motion controller... so you may need to review your system if it fits. If so, the API experience would be almost the same as NI 73xx series. FYI...
TENET EMotion getting started | LabVIEW motion control - YouTube
(2,224 Views)
