can I use Labview to control system of conveyor belt + hydraulic press? what is necessary?
dear all,
I would like to know if it is possible to use LabVIEW to control and syncronize the operation of a conveyor belt that feeds material into a hydraulic press.
If this is so, what would be required?
We need to be able to experiment and change the operation parameters until we find the "sweet spot"
example of parameters to change:
1. connveyor belt speed, from 8 m/s to 3,3 m/s
2. hydraulic circuit parameters:
- piston stroke
- relieve valve set pressure: from 2500 psi down to 2200 psi
these are just examples.
any comments / suggestions are appreciated
alvaro
(4,945 Views)
Duplicate thread
GCentral
(4,765 Views)
