Yes, modulus breakpoints can be used to generate pulses at even intervals through your moves. To do this, you would load your initial breakpoint position to determine what position value will be used for the first breakpoint and then set the breakpoint modulus to determine the position interval for subsequent breakpoints to be set. If your motion will be occurring in a grid, you can reset your breakpoint position for each line and then reload the modulus for the reverse direction.
Try this and let me know if you have any additional questions on this issue.
Scott R.
Scott Romine
Course Development Engineer
