i'm using a pxi-7358 for a single axis stepper move via an encoder.
i move up and down the axis to a series of positions using a modified example vi, single axis with position vi, .
i then intend to use another vi to perform a contoured move, again using a modified example, single axis contoured move.
I'm using Labview 8.20.
My question is: when i come to use the second vi with relative positioning the current position is still as the number of steps as fedback from the last move of the first vi. Where is the current position stored and how do i clear it?
Do i have to turn everything off at the end of the first vi before starting the contour move?
The encoder has no index position and i'd rather not use one of the end of travel limits.
many thanks
Darren
