connecting encoder DH053 to USB 6221 DAQ
Please I want to connect encoder DHo53-060e3n01 to USB-6221 DAQ to count pulses up and down and I don't know the right connections
please help
thanks,
ahmd
(6,505 Views)
Hi ahmd-
     Here is a document that explains how to connect your encoder to your 6221.  I assume your encoder has an 'A' and a 'B' signal.  Channel A and B will be connected to pin 37 and 45 (PFI8 and PFI10) if you are using counter 0 (CTR 0).
     I hope this helps.  Best of luck with your application!
Gary P.
(6,484 Views)
Thanks a lot eng.Gary
 thanks for your time and your interest
ahmd
(6,480 Views)
Hello, I realize this is a 3 year old message but was wondering if I could get that document. The link is no longer good. Thank you so much!
(5,850 Views)
Hi bowoods,
I'm not exactly sure which document you needed, but below I've listed a few resources that might be able to help you connect an encoder to a multifunction DAQ.
The first link below describes in general how you would connect an encoder to a counter
http://digital.ni.com/public.nsf/allkb/B3945A72AE53D1B086256EF7007C4D0D?OpenDocument
The second link is a forum post that talks about connecting a specific quadrature encoder to an M Series DAQ card. In it there are several links to articles on connecting encoders in LabVIEW
http://forums.ni.com/t5/Multifunction-DAQ/What-do-I-need-to-connect-a-quadrature-encoder-to-a-M-seri...
Gabriel M.
Product Marketing Engineer - Academic Courseware
(5,838 Views)
Thanks so much! These will do nicely!
(5,836 Views)
Please i cant get  the attachment
how to connect DH053-060E3N01 ENCODER
could you upload again?
thanks
(3,758 Views)
