03-26-2006 11:39 PM
03-27-2006 01:17 AM
03-27-2006 01:45 AM
Thanks. Can I get the output position data of Smart Contouring?
In the contoured move, the motion time between two continous points is the sampling period, is it correct? I am really confused with the stepper motor controll by 7344 using closed-loop control.
I developend an interpoaltor in which I set the time interval between two sequential interpolated point is 1ms and this value can be changed. To get the smaller chorderror, the time interval also should be small. When I do the experiment using contoured move (stepper motor +7344 +closed loop), the velocity is very slow. I think the reason is that time interval of the control loop is much bigger than the time interval used in the interpolator. This means the motion time between two sequential point is increased consequently decreases the velocity. Anyway I am not sure about this. Is anyone has any idea?
^_^
