control speeds by Joystick
hello,
first is this post on right section or not?
I wanna control the Date Control ( velocities in X, Y, and Z, and yaw ) in attached VI by using  a Joystick. And I enclosed the program in a while loop with a 1000 ms Wait to make it send every one second,but it does not work.
i need to know how to make those. And if you think my work is wrong, please tell me.
thanks.
(5,700 Views)
Hi marvel of future,
I noticed that you have the same discussion going on in another thread. Please continue working with the community there for now. Feel free to post a new message to this board again if you need specific help in working with motion control/motor drives. Thanks!
(5,689 Views)
thanks.
as you see, i didn't reach anything in the other discussion.
can you help me, please?
thanks.
(5,683 Views)
Hi marvel,
It looks like the posters on your other thread are just looking for a little more information about the specific device you are using. If you post a manual of some kind there, things should move forward. I would recommend doing that. Also, unless you are using a motion control board or motor drive for this setup, the question does fall under "Instrument Control," as you have correctly categorized in your other thread. Please try posting the manual or further information about the command set for the device you want to use in that other thread.
Matt J - NI Tools Network
(5,666 Views)
