convertion labview driver of nanomotion II from 4.0 to 7.1
I have a motor controled stage, with a model of Nanomotion II from Melles Griot company. I only have the labview driver in 4.0 version. Could anyone help me conver it to 7.1 version or 8.5 version?
Wei
(5,635 Views)
Here they are in LabVIEW 8.5!
-Zach
(5,609 Views)
Hello Zach,
Thanks for your converted driver. It works fine under Labview 9.0 (trial version), However, when I install Labview 8.6 in my computer and tried to run these drivers, there are some problem. The program gives the signal as follows:
Error 0 occurred at GPIB Write in MG Nanomotion II Reset.vi->MG Nanomotion II Initialize.vi->MG Nanomotion II Example.vi
Possible reason(s):
LabVIEW:  Error connecting to GPIB driver or device. This is usually due to a required driver not being installed on the system.
Could you help me make further conversion of the driver? I will really appreciate it again!
Wei
(5,508 Views)
You should have been able to redownload the files I posted above as they were saved in LabVIEW 8.5. Files in 8.5 should be fine to open in 8.6. Nevertheless, I have also attached the 8.6 specific version.
-Zach
(5,502 Views)
Hi everyone,
In my research group we have a few nanomotion controller II (11NCS101) with boards 11NIB003 and 11NIB007.. However these controllers came from different university, we didnt buy them. Since the company is sold, they dont have any documentation about these products.
Is there anyone who can provide me manual for these products. I'm not even sure about minimum step size and I need to use this controllers at their maximum resolutions. nanometer levels.
I have been trying to find out specifications with the codes provided but it's not working well
(4,848 Views)
I have some, what is your email address so I can send to you.
Wave
(4,843 Views)
Hi, I sent you a message for my email address..
thanks
(4,836 Views)
