dc voltage offset in PXI 7340
Dears,
I have an offset on my voltage output in NPXI 7340 which is amounted on PXI 1031 Chasis. For example when I demand zero volt there will be around 0.1 volt (measured) on the output, ...  and so on. Is there any way to fix/eleminate this offset?
(5,363 Views)
Hi AOA,
is this consistent across all analog outputs? Which outputs have you tried to find this behaviour and what number pins were they?
Kind regards,
Matt H
National Instruments UK
(5,347 Views)
