hello I generated the labview code from motion assistant for a two axis servo motor .I have two motors which has to be run simultaneously at different speeds.what concept should I use in labview for running the two motors with different speed?Pls help. I ve attached the code for one servo motor
Look at this example to see how you can load up different values for different axis and then call the start motion with a vector space reference to start motion on all axis together.
