error code -72015
I installed NI Motion 16 driver for PCI-7332 controller that is connected to UMI-7772 interface board. My LabView code is calling nimotion.dll function named nimcReadDigitalIOData(). Testing DIO was working at some point but now I am getting the error code -72015 and reading doesn't match the digital input. I searched this error code and nowhere to find. Can anyone, possibly developer of this DLL, let me know what this error code indicates?
(3,104 Views)
I found a reference to NI-Motion Error codes.
   http://zone.ni.com/reference/en-XX/help/372134F-01/ni-motioncreferencehelp/errorcodes/
The largest error code number is –70180. So, I am guessing this site is not updated. There is a big gap between -70180 and -72015.
Is there anyway error codes can be updated to the latest codes?
(3,088 Views)
Have you done any changes to the software or hardware of the computer recently? What would be very useful is a MAX Technical Support Report so we can check it.
Also, including the code would be very useful!
(3,068 Views)
Attached report is generated 4 days after the incident where error code -72015 was generated. Calling function is "Read Digital IO Data.vi" in the attached library.
(3,052 Views)
Attached a wrong report. This is correct.
(3,049 Views)
