02-14-2006 01:45 PM
02-15-2006 07:29 PM
CracKatoA,
"The refresh rate for the axis (axis 1) is 62.5 ms."
I am assuming you meant 62.5 us.
I need more information about your system. I started jumping to conclusions regarding how solve your situation and then I realized I was making assumptions about your system.
Can you tell me more about your ServoValve and the ServoValve's driver/amplifier.
There might be some solutions to your problem.
Tell me if I am correct or not, as the frequency of your oscillation increases the torque required to put your shock-absorber in a specific position changes. It sounds like there is some lag in your system that increases as velocity of your shaft increases. You might need a control system that can compensate for this lag or remove the component in the system which is allowing it to lag. Velocity feedforward gain (Vff) or Acceleration Feedforward gain (Aff) might help with this. Or... I might be completely off base and this might not be what is happening at all.
Anyway, if you could give me more information about your system and comment about anything I said, it would help me help you.
Lorne Hengst
Application Engineer
02-16-2006 09:07 AM
Thanks a lot Lorne for your kind reply.
Yes, you are right, the update rate is 62.5 us.
We have already used in our project the velocity and acceleration feedforward which did produce some better results in the overall performance of the damper machine. The real problem, which we are analyzing now before trying to keep pushing for additional betterments is that the hydraulic component of the machine itself seems too small for the required movements. The electronics cannot do magics in this case.
Our question about getting rid of the hardware control in the motion board was indeed somewhat silly since you may wonder why we are then using a dedicated board for that purpose if we do not want it to take control of the process. In this case, the problem was raised by our customer.
