find reference reverse direction
I have a simple motion application that I am trying to troubleshoot.
I am moving my motor from the home position to the user specified target position in the forward direction. I then want to return back to home (in the reverse direction). However, whenever I use find reference.flx to find home, it only wants to move in the forward direction.
How can I get find reference.flx to find home in the reverse direction.
LabView 8.6.1
NI-Motion 7.7
PCI 7334
(4,705 Views)
Accepted by topic author Paul567
Paul,
you can define the initial search direction and all other parameters for a reference move with Load Reference Parameter.flx.
Kind regards,
Jochen Klier
(4,699 Views)
Thanks for the reply Jochen!
Just so that I understand correctly, would I have to wire Find Reference.flx after the Load Reference Parameter.flx?
And, using Load Reference Parameter.flx could I load multiple parameters? (Example: Could I select the Inital Search Direction and the Edge To Stop On?)
(4,690 Views)
Exactlly. With Load Reference Parameter.flx you can configure the behavior of the subsequent reference move and you can chain multiple calls of this function in order to configure multiple parameters.
(4,686 Views)
Excelent!
Thank you very much for your time.
(4,682 Views)
