flexmotion6C pulse output
I am trying to get variable length digital pulses out
of the flexmotion6 board using the UMI-Flex6 terminal
block. Yusuf C, suggested I configure the axis to run on open loop stepper mode and tap the Step(CW) and Dir(CCW) lines during a simple move. This should
give a pulse train. And I can change the frequency by changing the velocity of the move.
When trying to configure axis 5 as a stepper
and running the 1-D interactive program under the
MAX program to test the axis, I get the error message "Error 70017
NIMC_StepperOnlyError Occurred in set stepper loop
mode (flex_set_stepper_loop_mode) on Axis 05
This command is valid only on a stepper axis"
I have also considered using the flex_load_DAC
command to load a value into the DA
C directly.
Is it possible to use this cammand with DAC 1
through 6, provided they are not associated with
an axis (ie. the axis is disabled or the DAC channel is
not selected for a particular axis.
Thanks for your help
(3,121 Views)
Ysusf's suggestion should work for you. The error which you are getting indicates that you are trying to change the stepper loop mode on an axis which is set up as a servo. To fix this change the axis configuration to stepper and then hit apply and initialize board.
In order to use the DAC on a channel it must also be configured as a stepper. And then you can do the load DAC. I'm not sure how this is to be a substitute for outputing a pulse train but if does the trick then great!
Amaury Rolin
NI Applications Engineer
(3,121 Views)
