from nt to 2000: vis work but some have error: in device 52 on flex_read_adc
we just moved an application from windows nt to windows 2000. we use a pci-flexmotion 6c and the 5.1.1 driver with a patch. the application is generally working, but with some vis there comes the error-box: "in device 52 on flex_read_adc".
(3,096 Views)
From the appearance of that error dialog it doesn't seem to belong to any error generated by the FlexMotion driver. It looks a lot more like a user defined error dialog that might have been made by whoever coded your application. I would ask them, or , if you prefer, you could send us your code by contacting an applications engineer at 1-866-ASK-MYNI or posting it here. We will gladly ty to reproduce the problem and let you know where the error is coming from.
(3,096 Views)
i think i found the error. i did assign the adc whose adress caused the error to a free axis (we only use 4). then the error didn't appear anymore. before we moved to win2000 this was not necessary, it was possible to access any adc directly from the program without configuring it beforehand. i don't know what you do if all axis are used. maybe it's sufficient to configure the adc as a secondary feedback.
(3,096 Views)
