how long does it take for 7344 to settle down to the required speed
hi
I have to drive a motor at a particular speed using 7344. i owuld like to know what is the optimum time that 7344 takes to settle to this speed.
(3,013 Views)
That depends on the characteristics fo your system. Remember that every position or velocity move you execute is cgoing to correspond o a trapezoidal profile, where you will have an acceleration and maximum velocity section. Depending on the values you set for acceleration either through MAX, LabVIEW or your programming language of choice, as well as the maximum velocity you require to achieve will depend the time it will take for your motor to reach teh velocity. Remember that a system with high inertia will take tlonger to overcome friction and gravity than a low inertia one and that if you are using Servo motors, the PID values you have it tuned to will affect its repsonse too. Please refer to the following document:
http://zone.ni.com/devzone/conceptd.nsf/webmain/
4B7775373E4AE64986256B6000691505?opendocument
For any questions related to tuning.
(3,013 Views)
