how to program ELMO motion controller with labview via Ehtercat on compactrio9035?
I have build a set system of compactrio9035 and elmo driver with labview, six i/o port can be show in labview via ethercat,but i dont know how to program communication between above,
who can help me?thanks!
(3,940 Views)
Hi Mrxiong,
Have you considered using the SDI Plugin for SoftMotion with this drive? If not, I highly recommend this since it will provide you with the much easier SoftMotion programming.
Thanks!
(3,918 Views)
your motor drive has been discovered in the Project which is the first step. Now, you also have to add a Softmotion Axis and also a Softmotion Coordinate Space by right-clicking on your Controller and selecting New->...
Then you can drag-and-drop your Axis into a project .vi and use it as a ressource for motion control.
(3,818 Views)
